Old 04-28-2013, 08:24 AM   #1
leak from pulled in slide
We noticed this strange place to find a leak. Its the dark spot on the carpet by the wall outlet. The slide was in when this happened. Anyone have any ideas? Thanks!
tjvpga is offline   Reply With Quote
Old 04-28-2013, 08:28 AM   #2
fonzie's Avatar
Please post what RV model you have and year. Also which slide is leaking?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-28-2013, 08:35 AM   #3
Its a 2012 Georgetown 327, Its the slide in the kitchen/living room.
Old 04-28-2013, 09:01 AM   #4
fonzie's Avatar
If it is water and wet, then either you have a leak from the seals on the slide or a leak from the shower (p-trap, faucets or bad caulking somewhere). Close the slide and see if you see any light coming through the seals. Also check your shower plumbing and p-trap under shower base.
Fonzie
Old 06-21-2013, 03:03 PM   #5
fonzie's Avatar
Did you ever found what the leak was?
Fonzie
Old 07-02-2013, 08:42 AM   #6
I have the 2011 Georgetown 327, I have a leak in the same spot. They are unable to locate the source I had a leak test completed they re sealed area yet I still have a leak. Anyone find a solution to this problem please email me.
Eric Healey
ehealey@dominionlendiong.ca
Eric Healey is offline   Reply With Quote
Old 07-03-2013, 01:38 PM   #7
Anacortesians
If the seal design hasn't changed much since my '02 325 was built, you may have a "roll-over" of part of the vertical seal on the wall. The seals are fairly soft and flexible, so any minor piece of debris can cause the free edge to fold in on itself. We had an issue with the top seal on the dinette slide (the one on the outer body immediately above the top edge of where the slide travels in and out).
Also, I've found that Georgetown's adhesive application techniques were poor in '02. I've had to reattach several sections of slide seals in different places. Fortunately, most were low down and used more for draft and critter seals than for rainwater.
Frank and Eileen
No longer RVers or FR owners
