Old 07-08-2014, 07:46 PM   #1
Wildwood Danny's Avatar
Leak in slide out
Have developed a water leak in corner of slide out under dinette storage area when it rains. Have checked all of the caulking and sealing on slide and around windows and all appears to be good.
Need ideas.
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club, Cedar Creek Sams Chapter
RVing is a tough job,BUT someone has to do it!
Wildwood Danny is offline   Reply With Quote
Old 08-01-2014, 10:01 PM   #2
I have a similar issue. I discovered wet carpet and some swelling of the board on the inside front of my slide on the rear portion and damp mildewed carpet under the dinette seat. I removed the seat and let the carpet dry. Outside along the lower edge of the slide wall the interior paneling extended to the very edge of the lip of the trim piece and a 16'th of an inch below at one spot. It was exposed to the weather I think the rain water running down the side of the slide was being wicked up into the wall of the slide onto the carpet. The edge of the paneling was already crumbling away. I cleared as much of the bad away from the bottom edge and took a tube of geocel and sealed the wall edge up as best as I could. Waiting now to see if anymore water makes its way in.
Same problem from this link, slide out leak
tvengineer is offline   Reply With Quote
leak, slide, slide out
