Old 11-04-2018, 03:26 PM   #1
Question Leak (under) I think BOTH slide outs when driving in the rain.
Chaparral 30RLS (2017) 5th wheel.
A couple of issues really.
1. With the drivers side (kitchen side) slide-out - OUT - you can see light under the lower edge. I've been under there and the bottom (inside) wiper seal has a notch cut out at the two (2) metal slide arms. The seals just flap down at these spots leaving - really no- seal at all. WTF.
2. When the MAIN and KITCHEN slides all in and appear to have a solid seal - when driving in the rain / wet we get water on the floor (both sides). WTF
HELP ... anyone with a similar Fifth with a solution?
X_Medic 73 is offline   Reply With Quote
Old 11-04-2018, 04:06 PM   #2
need to go around and check the seals when closed and look for anyplace water may get in . i've seen many a slide out that the bottom seal was almost non functional . may look at replacement seals that are a bit wider . if under warranty maybe you can get a stealer to do it
MR.M is offline   Reply With Quote
leak, slide, slide out
