Old 05-03-2019, 07:47 AM   #1
Grapelape's Avatar
Leaking slide
The slide out in our 2018 Wildwood leaks on the bottom right corner (corner closets to front of camper) when it is pulled in. Looked like caulk on that corner was crumbling so I recaulked it. Seemed to be working. Went camping. Had lots of rain, no issues. Go back to camper 4 days later, floor and slide out around that corner are wet. Canít figure it out. Please provide suggestions. Thanks.
Chris
Grapelape is offline   Reply With Quote
Old 05-03-2019, 08:05 AM   #2
njfishing's Avatar
Hmmmm. So this only happens when the slide is pulled in but not when it's out?
Gerry Z
2014 Roo 21DK
Honda Ridgeline
Equalizer WDH
njfishing is offline   Reply With Quote
Old 05-03-2019, 08:19 AM   #3
KyDan's Avatar
My slide can seep both when in or out even tho the seals look good. I found that if I park it just -slightly- low on the slide side it stops.
I'm talking the bubble is just touching the line rather than exactly in the middle between the lines.
(bubble would be touching the line towards entry side since our slide is other side from entry door.)
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 05-03-2019, 08:38 AM   #4
Brother Les's Avatar
Originally Posted by Grapelape View Post
The slide out in our 2018 Wildwood leaks on the bottom right corner (corner closets to front of camper) when it is pulled in. Looked like caulk on that corner was crumbling so I recaulked it. Seemed to be working. Went camping. Had lots of rain, no issues. Go back to camper 4 days later, floor and slide out around that corner are wet. Can’t figure it out. Please provide suggestions. Thanks.
Look at the top of the slide and see the position of the top 'flap' and the side 'flap'. If the side flap at the top is over the top flap, then water will be channeled down the inside of the whole side flap. Make sure that the top flap is over the top of the slide flap, this will channel down the out side. Bringing your slide in and out a few times over time, may have changed the position of the flaps as the flap drags along the slide and you may not have noticed that the arrangement has changed and what will happen because of this change.
Also, have your slide side have a halve bubble tilt to the slide side. With rain hitting the top of the slide, you want this water running to the edges. If your unit is 'true' or slightly tilted to the non slide side, water will build up on the slide roof and 'find' a way to infiltrate to the inside. A 'slide' is never truly 'sealed', so you must find a way to direct the water coming at your unit.
Brother Les
Old 05-03-2019, 09:03 AM   #5
Grapelape's Avatar
Interesting. I thought about making sure the camper tilts slightly back when in storage. Thanks.
Chris
Old 05-03-2019, 09:05 AM   #6
Grapelape's Avatar
Are you talking about when the slide is in or out on both of these?
Chris
Old 05-03-2019, 09:07 AM   #7
Grapelape's Avatar
Yes. As far as I can see. I wondered if rain water was trapped when the slide was out and leaked inside once it was closed, but would there still be water and moisture on the slide and floor 4 days later?
Chris
Old 05-03-2019, 09:08 AM   #8
Grapelape's Avatar
Also, is this what you do when the slide is in or out?
Chris
Old 05-03-2019, 09:11 AM   #9
njfishing's Avatar
I think Brother Les hit the nail on the head.
One other thing that might help you is a Slide Topper but even if you do decide to get one, you should make sure this problem is solved without one.
https://www.campingworld.com/black-s...RoCthUQAvD_BwE
Other benefit of the slide topper is not having to worry about any leaves or branches that might make their way on top of your slide..
Gerry Z
2014 Roo 21DK
Honda Ridgeline
Equalizer WDH
Old 05-03-2019, 09:16 AM   #10
Grapelape's Avatar
Yes, I need one of those.
Chris
leak, slide
