Old 07-20-2019, 07:17 AM   #1
Leveling Jacks
My slide outs and leveling jacks have a mind of their own if jacks are up one slide out is out. If jacks are down slide out is in. The nut to use a drill motor to raise jacks manually is striped. Is there a way to retract the jacks and manually push slide out in? Or is there a manual way to push jacks up without using power? Help.
Janmc is offline   Reply With Quote
Old 07-20-2019, 10:42 AM   #2
Jim34RL's Avatar
First off what trailer and year! Plus are your slides and jacks hydraulic on electric? There are many different system in the RV world and this information is needed for us to answer your questions and help!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 07-21-2019, 04:51 AM   #3
2014 Forest River Georgetown 360xl and yes they are on electric...according to lippert I need to locate"the brain" for the leveling system and they will replace it.Any ideas where this may be located in my RV? In the meantime I need to move my RV and need to get the jacks up somehow.
Old 07-21-2019, 10:36 AM   #4
Jim34RL's Avatar
I would post the request in the Georgetown threads asking were is the control unit located.
My trailer is all hydraulic and is a 5er so, my controls will be in a different location and type.
Jim W.
Old 07-22-2019, 07:58 AM   #5
blwnsmoke's Avatar
MY brain is mounted under the 5th wheel section in the storage area. When I open the storage door and look up, you can see it bolted with 4 harnesses going to it (one for each jack). Although not the same brand, you may just want to take a look there.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
jacks, leveling
