07-04-2015, 06:45 AM
#21
Both sets of my Lippert stab jacks will adjust to the terrain, but once the load is on them they do not shift under the trailer. It appears that the slides were extended and then the trailer stabilizers deployed. As has been pointed out numerous times, they are stabilizing jacks, not leveling jacks.
07-04-2015, 06:54 AM
#22
Very Easy to (Level) side to side! Youroo!!
07-04-2015, 07:05 AM
#23
Or with Andersons.
07-04-2015, 07:19 AM
#24
I roll with the Anderson leveler too.
07-04-2015, 07:48 AM
#25
I use Anderson too.
Sent from my XT1060 using Tapatalk
2014 Tracer Ultra Lite 2670BHS
2014 Ram 1500 Crew Cab 5.7L Hemi
Camping Trips 2014 - 3 trips, 7 nights
Camping Trips 2015 - 2 trips, 4 nights
(7 more trips planned)
07-04-2015, 09:29 AM
#26
Anderson here too.
07-18-2015, 11:51 AM
#27
Jacks
Originally Posted by stansoper
On my 11th day camping(2 trips) with my new 2015 Wildwood 29FKBS TT. I'm having problem getting my unit level, side to side. It has two slides, both on driver side. One with hide-a-bed and dinette with 4 chairs. Other is short queen bed. When I pull in I un-hook and get the the unit level, and extend the stabilization jacks. Then I extend the slides. Once I do this, the unit does not maintain level. It leans to the slide side. I love the unit, but wish I could get this leveling thing down. I have no problem with the front-to-back level, just side-to-side. Does anyone else have this problem? Suggestions please. Thanks.
They do make jacks for the side outs.
07-18-2015, 11:57 AM
#28
Which will destroy a slide out if you happen to have tires go flat or sink in the ground. DO NOT USE SLIDE JACKS! even if they are free.(which they are not)
07-18-2015, 11:59 AM
#29
Stand jacks can be used but not recommended, they can damage your TT slide frame.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
07-18-2015, 03:13 PM
#30
I always set the slide side high.Usually 1 1/2-2 inches.works
07-18-2015, 03:23 PM
#31
Georgia Rally Coordinator
I will check the side to side before I disconnect the trailer. It might say level. I found out with my unit that had two slide on the same side would always be off so I would just use my 4 ft 2x8 and run up on this. Once disconnected from TV I would then finish setting up and and all would be level. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-27-2015, 03:04 PM
#32
My wife and I have a 2000 FR Sierra FKSS 30ft tt that we bought 5 years ago. The slide is hydraulic and we have not had any problems with it-or anything else for that matter-knock on wood. I would love to get a Windjammer 3008 some day, but it scares me to spend that much with all the problems I read about. I also set up with the non slide side a little lower before putting the stabilizer jacks down and then putting the slide out. However with my manual jacks I can use them to level some as needed and have very little movement when walking inside.
07-27-2015, 03:27 PM
#33
hondo; You should look at the V-lites as so fsr I've owned two and have had very few warranty repairs. First one was the 30WIKSS which I think is same floor plan as the 3008. With some of the wall cracking issues on the Widjammer I'm glade I did not buy the second time around. Trailers are almost Identical so why the issues guess where they are made. Later RJD
Days camped 2019 62
08-12-2016, 10:12 AM
#34
Would it be safe to use these jacks under the TT frame itself on the slide side? We have been leveling with the slide high but after a day or two it seems to drift down.
