Old 06-22-2009, 05:50 PM   #1
Pete
gartonhl's Avatar
Lippert hydraulic slide & level system
I have a 2005 Georgetown 325 DS. All working fine until a couple of weeks ago. Found 7.5 amp blown AUX fuse under steps by house batteries and replaced .
Now, power leveler console in dash operates in "all extend", but, 3 levelers go down-D front, Pass front, D rear and then living slide goes out, not Pass rear---I have to do that one separately. I've checked hydraulic valves and all are closed and tight.
Any one experienced a similar situation?
gartonhl is offline   Reply With Quote
Old 06-23-2009, 11:17 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I haven't had any issues with my levelers thank goodness but you may want to contact Lippert directly and explain your situation. Hope this link helps.
http://www.lci1.com/
Here's a troubleshooting link. If it doesn't load use the above link and choose LIP under the SUPPORT Column. This is # 0021.
http://www.lci1.com/LIP/0021.pdf
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
