Old 08-23-2015, 09:19 PM   #1
Lippert IRC (Individual Room Control)
I have a 33IK that has the 3 knobs for IRC. According to Lippert and other posts I have read the IRC will allow you to to control one slide at a time.
How do you use this? I turned one to left today (bedroom) but all rooms still retracted? Anyone use these and how or when.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-26-2015, 07:48 AM   #2
Jerry01's Avatar
Do you have these knobs?Click image for larger version
Name:	ImageUploadedByForest River Forums1440589576.703021.jpg
If so then I believe all the way closed will prevent slide from operating. I have closed the rear two slides and the front still worked. Sorry for the blurry picture. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 08-29-2015, 09:48 PM   #3
Yes, I have that valve system but they mounted it to a bulkhead. I guess if you completely close the valve then it stops the flow to that particular slide be it keeping it shut or leaving it out if it is already out. Thanks...
2016 Siverback 33IK
Old 08-30-2015, 09:24 PM   #4
Jerry, Thanks.. I shut two of the valves, fully clock wise, and those slides stayed out while the third slide retracted. Like you said, it shuts down hydraulic action to the slides you have shut down...
2016 Siverback 33IK
roo
