10-17-2019, 04:51 PM
Lippert motors
2017 Crusader slide moter bad,2 yrs old been opened maybe 25 times,I no genius but anytime you place a plastic gear between two metel ones,whats gona happen? Like I said it's not rocket science!! So $480 later and several hours spent on my backside it's working again! Poor design as far as I am concerened!
10-19-2019, 07:58 AM
Quick question you had to buy the entire motor to get the gear?
Retired Navy
2016 Flagstaff 26 FKWS
10-20-2019, 04:41 AM
Well at the time I did not know you could get replacement gears, now I do. Will order them and rebuild the one I have so I can have a spare moter when the other one goes out,which im sure it will at some point,still a crappy design!
10-20-2019, 04:44 AM
Well I know now I diden't.have to,I now have a spare for when the other one goes out,which I am pretty sure it will at some point!
10-20-2019, 05:36 AM
Where do you order the plastic gear?
2013 Flagstaff 831FKBSS
10-20-2019, 08:10 AM
I bought mine from Amazon.
Many only places have them.
(eTrailer, Dyers, Ebay)
10-20-2019, 08:34 AM
Bought new motor from etrailers and they said they did not have gear.
Will check again. Thanks
10-20-2019, 01:24 PM
AMAZON has them or e trailer also..
10-20-2019, 01:39 PM
Sometimes, a plastic gear between two metal ones like that is there for a reason. It acts as a mechanical fuse. If something binds, that gear gets destroyed rather than some other, more expensive part. Other times, it is just a poor design.
I would check and make sure that nothing is binding in your slide. Then you'll know that it's the latter.
2020 Cherokee Grey Wolf 18MT
TV: 2014 RAM 1500 5.7 Hemi
10-20-2019, 01:55 PM
Slide goes in and out by hand just fine,just takes 30 min to crank by hand,also no pass through on the frame had to get closed end 5/8 rachet wrench and open up the under side to get to, more BS,why they would give you a crank handle you cant use is beyond me...
