Old 06-01-2008, 09:40 AM   #11
Thank you C & S. I had the same thing with my slide. I called like you said and got the gead sex for 50.00$ . Put it in yesterday and all is good.
panamoka is offline   Reply With Quote
Old 06-02-2008, 10:08 AM   #12
I mean
It should have read gear set.
Old 06-18-2008, 11:34 AM   #13
What happend
So how did you makeout iowacamper?
Old 06-18-2008, 12:01 PM   #14
I just read these............
The T is nowhere near the X on the keyboard so that makes it even more funny!!!
aintgotnun is offline   Reply With Quote
Old 05-09-2011, 11:39 PM   #15
Thanks for the supplier. I had to buy a min of 10 so I have some spares. E-mail me if you would like one or two. choldteach@yahoo.com
teachforever is offline   Reply With Quote
Old 07-25-2011, 06:32 AM   #16
I also have a stripped slideout gear. I have ordered through Venture Mfg. Co. Get on their website and email them. I have to buy 5 sets (minimum of $50) of the two gears (8504-01 and 8579-11) reduction and clutch. Lippert Mfg has it as 95-1249 or 14-191072(045-191072). You might check because a Barker Mfg also has slideout parts. Take photo and send it to them and they will tell you which it is. Good luck. PJ
pjoz98 is offline   Reply With Quote
Old 08-26-2011, 01:10 PM   #17
Lippert Motor Gear- HELP
I have an EZBedLift motor from Lippert part number 137669 and the tefflon gear is worn just enough that it does not engage. Lippert does not sell the transmission guts separately thus I am hunting for just this gear. I called Ventura Mfg but they don't carry this. Any other options?
Attached is a pic of the gear and the transmission without the actual motor attached
Name:	hauler pic 1.jpg
ID:	7619   Click image for larger version
Name:	gear to transmssion.jpg
gmgregg is offline   Reply With Quote
Old 08-26-2011, 03:39 PM   #18
You can send a photo of the gear to Barker Mfg and they can check if they handle it.
Old 09-26-2011, 07:06 PM   #19
Im looking for that part also..Did anyone have any luck?
rgriff is offline   Reply With Quote
Old 09-26-2011, 08:00 PM   #20
georgetown's Avatar
My slides are different, they are all hydraulic, however, I purchased some things from rvupgrades.com in the past and noticed they carry some lippert parts, here is the link, hope it helps you guys out.
Lippert Repair Parts
2010 Georgetown 330
Ontario, Canada
georgetown is offline   Reply With Quote
