Old 05-01-2008, 04:06 AM   #1
iowacamper's Avatar
Lippert slideout motor gear!!
I got a CD stuck in my slideout and it stripped that nylon gear out in the slideout motor. To my surprise Lippert doesn't sell that nylon gear that they make to strip out easy separately. Does anyone know where you can get that gear from or have had that problem happen to them. I really don't want to purchase a whole new motor for $500 on a 2 week old camper. They wont warranty it out either!!!
iowacamper is offline   Reply With Quote
Old 05-01-2008, 06:52 AM   #2
Lippert Motor
I had a similiar problem in another coach. Unfortunately, the electric motor is sold as a complete unit and no parts are available to simply repair it. I found a motor at a used RV parts dealer and got one for half price. There is a Sands RV in Ohio that sells overstock parts for RVs and may have a motor. Good Luck!
Crossfire is offline   Reply With Quote
Old 05-01-2008, 08:37 PM   #3
powerboatr's Avatar
i would be doing a tap dance on someones desk tilll it was warrantied out.
aint no excuse for a cd to cause such a severe issue
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 05-02-2008, 10:27 AM   #4
Rockinwood's Avatar
I agree, if you Dealer wont budge, take it to another dealer and dont mention the little plastic cd that can cause a motor to be replaced, if that doesnt work ,contact Lippert, I bet they send you a new motor(if they care anyway)
A smaller problem I had recently, my tornado gears came apart where you screw in the hose, not stripped. I contacted Camco the Manufacturer, and they sent me a new one with a brass thread. Just an example if they care.
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 05-02-2008, 10:36 AM   #5
welshman599's Avatar
Send a message via MSN to welshman599
My slideouts don't play CDs so I haven't run into that problem.
Sorry couldn't help finding the cause a little funny. My system's hydraulic and nothing stops that sucker from its journey. Retracting one with a bicycle trapped underneath it just rams the handlebars though the slideout skirt.
I suspect that the nylon gear is pressed-on the shaft rather than keyed or splined so that's why it isn't available as a replacement part. But if you haven't already reported the stuck-CD issue, and given the newness of your trailer I'd go to the dealer and say it just stopped working.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 05-04-2008, 06:32 PM   #6
iowacamper's Avatar
I actually pulled the nylon gear off already. It was just that easy. My other 2 slides are hydraulic. This is just the bunk room that's elecric. Actually it was a dvd. lol. I called lippert and they are the ones who don't want to warranty it out. I'm actually going to try and reach someone higher up at lippert. Thanks for the info
2009 Sandpiper 345QB
2002 F-250 V10
wife, 3 kids, and a dog
" We take camping to a whole nother level "
Old 05-04-2008, 08:17 PM   #7
MRimmer's Avatar
Been doing some searching and seems Lippert has had some problems similar to this.
KEEP BEATING ON THEM!!!!
Google was my friend.
Contact info
Jason Lippert (President - CEO)
Scott Mereness (Chief Operations Officer - Executive VP)
Gary McPhail (Chief Financial Officer)
Jamie Schnur (Chief Information Officer)
Jason Falk (National Operations Manager)
Matt Hazelbaker (National Operations Manager)
Todd Driver (National Operations Manager)
Marc Grimes (National Operations Manager)
I bet Jason could get you a gear
http://www.lci1.com/index.html
http://www.lci1.com/location_map_indiana.html
MRimmer is offline   Reply With Quote
Old 05-04-2008, 11:47 PM   #8
Hello,
I went thru this, Lippert Components is no help. The link below is the company you need to speak with. I believe that the stripped plastic gear is in the gear box, not the high torque motor, at least that's what happened to mine. I purchased 2 plastic gears, 1 to have as a spare, and they were around $12.00. I also purchased a spare motor, because that same motor will work on any of the 3 slides we have. The entire motor, not including the gear box, are you ready, was less than $100.00. You will have to open the gear box to change the plastic gear, not a big deal. The prices may have gone up slightly from what I paid, but nothing like the nonsense you are being told. Good luck.
http://www.venturemfgco.com/
Craig & Shirely
2008 Georgetown 391
"Gas Pusher"
Daughter- Alyssa
Pup- Sabrina
C&SAsh is offline   Reply With Quote
Old 05-05-2008, 12:12 AM   #9
Hi again,
This is so typical, the manufacture of the slide out told you that you cannot repair this, wow!!! Lippert Components is noting but a fabricator, for RV manufacturers, they don't care about us.
I was able to find this info from my order, contact Sue Haller @ Venture MFG. 937-233-6832 ext 28.
Hopefully she still works there, you never know. I think you will need a 28:1 gear ratio for you application. motor stock #8532-08J, gear set stk# 8599-10
Like I mentioned before, I went through this when we had our 5th wheel, my daughter held the slide out button in the retract position, and by the time I got to her is was too late, stripped stripped stripped.
Take care.
Craig & Shirely
2008 Georgetown 391
"Gas Pusher"
Daughter- Alyssa
Pup- Sabrina
Old 05-06-2008, 03:40 PM   #10
iowacamper's Avatar
you guys are so awesome. I actually got that plastic gear out and Im going to call for that plastic gear. If that company still has them Im going to get like 5 of them. Thanks again very much and I will keep everyone up to date on what happens espcecially if someone else has the same problem!!!
2002 F-250 V10
