Old 01-28-2016, 06:56 AM   #1
WaltCole's Avatar
Living/Dining Slide not sitting flush
Forgive me, I'm definitely green when it comes to Slide Out Traveler Trailers.
I have a 2015 Heritage Glen 302FK. My question/concern is: When I extend the Large Living/dining slide, it does not seem to seal and flush with the interior wall. Is this normal or does it need to be adjusted? On a side note: along the top on either side of the slide it is closer to the wall than the bottom. I do plan on calling the dealer service department today and ask the same questions.
Any help or advice will be greatly appreciated.....
WaltCole is offline   Reply With Quote
Old 01-28-2016, 07:02 AM   #2
Needs adj! Should be same contact all 3 seals inside and out! Been there! Youroo!!
Old 01-28-2016, 07:11 AM   #3
WaltCole's Avatar
Is this something I can do or does the dealer/service department need to do this?
Old 01-28-2016, 07:16 AM   #4
Members have performed the adjustments but if still under Warr. let the Dealer adjust it! Youroo!!
Old 01-28-2016, 07:28 AM   #5
WaltCole's Avatar
Definitely still under warranty, Thanks for the advice!
Old 01-28-2016, 02:56 PM   #6
I have the opposite problem. Both LR slides are kicked out about 1 1/2 inches on the bottom. Dealer says its ok, but looks funny.
Rick_Geneseo is offline   Reply With Quote
Old 01-28-2016, 05:56 PM   #7
Please explain was a "kicked out" is?
reg1943 is offline   Reply With Quote
Old 01-28-2016, 06:29 PM   #8
Platokidd's Avatar
Most slide out adjustments dont require a sawsall.
And there would have to be a awful lot of explaining
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 01-28-2016, 10:27 PM   #9
That is why This Adjustment was performed at the F/R Factory! Our simple Little Adjustment turned into a all day Plus overtime for 5 guys in 100+ Deg F Heat! Youroo!!
Old 02-09-2016, 04:04 PM   #10
The top of the slide is flush with the side of the trailer. The bottom sticks out away from the trailer.
slide
