Old 07-12-2010, 11:52 AM   #1
Location of manual slide access?
Hi folks, on our 2006 Flagstaff TT 831RLSS I forgot where the access for the manual slide bolt thingy is located. You know the one that you use to jack it in if the motor fails.
Thanks in advance!
JAck
jackhartjr is offline   Reply With Quote
Old 07-12-2010, 01:46 PM   #2
Thanks in advance!
JAck
Good question...... I have no clue on where mine is....anyone???
2006 FR/Wildwood 27BHSS
2006 Dodge laramie 5.9 CTD
northstarfire0693 is offline   Reply With Quote
Old 07-12-2010, 02:40 PM   #3
Wanna Be Camper
SaskCampers's Avatar
There should be a hole about 1 or 1 1/2 inches in diameter on the opposite side of the trailer to the slide where you put the tool in. Should be close to the bottom edge of the trailer side. If you look under the trailer where the slide rails are the hole should be inline with one of the rails.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-12-2010, 03:02 PM   #4
Thanks so much, I will let you know I found it!
(Was in GA New Years, cold as you know what and ran the battery down to the point the slide was hard to get back in.) Looked for the location, thinking it would be on the slide, guess it was wrong.
And I am sure that was not covered in the preinspection at the dealer.
Thanks again!
Jack
Old 07-12-2010, 07:46 PM   #5
Cyber Phrenologist
Radio's Avatar
On my Rockwood 5th wheel it is located under the entrance door. Fold down the steps, get on your hands and knees and look under the door. *IF* like mine there should be a hole there to put the crank handle into.
Same handle manually raises/lowers the landing gear. That hole is inside the curb side LP tank compartment, behind the tank, taped over with black tape. They really tried to hide that one. And if you carry some 30 amp fuses and know where the landing gear inline fuse holder is, (near the battery) you won't need to crank it very often!
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
