Old 06-26-2016, 03:43 PM   #1
Location of shear pin
I thing that I may have a broken shear pin on the dining slide. Only the side near the back moves, front by the door does not. Where can I find the shear pin to check? The slide is out now and will not retract.
2014 Cedar Creek 36CKTS
2013 F350, 4x4,6.7 diesel,CC, DRW 3.73 rear
B&W companion hitch
kautzmank is offline   Reply With Quote
Old 06-27-2016, 04:14 PM   #2
The shear pins are located in the coupling on the motor shaft.
Have you looked at the slide controller to see what lights are on?
Gotta go campin!
Old 06-28-2016, 08:00 AM   #3
Thanks for the reply. I found the shear pin, but that was not the issue. The gear had moved and was not meshing with the rail teeth,
B&W companion hitch
Old 06-28-2016, 08:08 AM   #4
Seems to be a recurring issue as of late.
This is the 3rd or 4th report of the exact same problem just in the last few weeks.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-28-2016, 01:54 PM   #5
Seems to be a rash of that happening like 5P said. Don't know if it's a mfg./design problem or an installation problem.
Gotta go campin!
cat, location
