Old 06-03-2019, 06:48 AM   #1
lubricants #slides
Whats everyone prefer? Silicone? What's the best to use to keep them lubed up!
Bryan294bh is offline   Reply With Quote
Old 06-03-2019, 06:54 AM   #2
Kasual Kamper
Actually, depending on the manufacturer, they recommend NOT lubing them! Too easy to attract dirt and grime.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-03-2019, 06:57 AM   #3
forest river says silicon maybe because its not as sticky?
Old 06-03-2019, 07:19 AM   #4
My warranty required inspection and lubrication of seals every 90 days or could void warranty if there is a failure. 2018 Cherokee Patriot Limited Edition.
TheWolfPaq82 is offline   Reply With Quote
Old 06-03-2019, 07:34 AM   #5
Mr. Dan's Avatar
Saying Forest River May be too broad. Different divisions might have different recommendations.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 06-03-2019, 07:37 AM   #6
well the Cherokee line says silicone so what I used..
Old 06-03-2019, 07:48 AM   #7
Mr. Dan's Avatar
Thanks for clarifying. We try to help members distinguish among divisions since many of them have unique manners of acting.
Old 06-03-2019, 08:02 AM   #8
RACarvalho's Avatar
Once a Year, in the beginning of the season I apply:
1 - Slide and windows seals: 303 rubber protectant (https://www.amazon.com/303-30313-CSR...SIN=B00KN0UOEE)
2 - Slide track system, slides at bottom slides and stab. jacks: Blaster Dry Lube (https://www.lowes.com/pd/Blaster-Har...ricant/1066849)
Dry lube is really good in providing lubrication but avoiding creating a "sanding paste" when dust gets to the parts after application, which can happen with wet lubricants.
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
RACarvalho is offline   Reply With Quote
Old 06-03-2019, 08:10 AM   #9
Lube
I use the slide out lube I also use it on the stabilizing jacks
2019 ROO 233S
2017 Dodge Ram 1500 Laramie
Wisconsin-1 is offline   Reply With Quote
Old 06-03-2019, 08:29 AM   #10
I use Aerospace 303 on the slide seals and WD-40 Dry Lube with PTFE on the mechanism.(s)
Days Camped: '16=46 '17=30 '18=51 '19=42
slide
