M-Tec/Lippert slide spur gears-help!
Found this gear at Grainger. Easy enough to remove the shoulder. Already bored and keyed. The existing gear will need to be measured and verified as to the correct one to purchase. When reassembled, make sure the gear teeth on the spur gear are not bottoming out on the rack. If they are, adjustment will be needed.
You could contact Motion Industries in your area, take them the gear and they will quote it, bored, keyed with shoulder removed. They do counter sales to the public.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
