Old 04-25-2018, 10:33 AM   #1
M-Tec/Lippert slide spur gears-help!
Good afternoon,
I have a 2011 Blue Ridge 3025RL which we bought used about a year ago. We have 2-3 teeth broken on one of the spur gears so that the two sides are not coming in evenly and we periodically hear loud pops. We can push it out while someone starts and stops it with the switch, but it never makes full contact.
We had our mobile RV repairman out and both he and us thought it would be a relatively simple matter of ordering a gear pack and replacing that side. We found out that we would need to buy an extra set of spur gears since they have changed from 2” to 2.5” and we would need to switch them out to fit our system but that was no big deal because they are cheap. Now, however, it has turned into a much bigger deal.
Apparently our system was originally manufactured by M-Tec which Lippert bought out afterwards. They are now telling our repairman that they no longer manufacture or sell the original M-Tec spur gear that is “obsolete.” He has made multiple calls to Lippert who insist the only solution is to replace the entire hardware system under that slide which is extremely expensive and labor intensive. No matter what search parameters any of us use to find M-Tec spur gears we are automatically directed to Lippert and eventually to their directions on converting to 2.5” systems.
I was wondering if anyone else has had to deal with this or has any information on the compatibility of Lippert and M-Tec spur gears. We are frustrated beyond belief as the difference in the two repair scenarios is literally a couple thousand dollars. How can they just buy a company and shut down the production of parts that their own customers need? Any assistance, information or suggestions are appreciated.
Kayleebou
kayleebou is offline   Reply With Quote
Old 04-25-2018, 11:10 AM   #2
Head Rambler
I can't find much about the M-Tec system, but RVupgradestore.com has several different gear packs of different sizes.
Is there any way you could post a few pictures of the system and the affected gear?
Gotta go campin!
Old 04-25-2018, 01:03 PM   #3
Pictures
These are the pictures and diagrams i have on my phone from messaging back and forth with our repair guy. I appreciate your time!
ID:	169552   Click image for larger version
ID:	169553   Click image for larger version
ID:	169554   Click image for larger version
File Type: pdf 2_x_2_hydraulic_through_frame_slide_out_assembly.pdf (1.53 MB, 14 views)
Old 04-25-2018, 01:52 PM   #4
The gear removed
He just sent me a picture of the gear removed. The inside is not hexagonal like Lippert’s stock gears so we can’t just interchange them, unfortunately.
Old 04-25-2018, 03:52 PM   #5
Head Rambler
Does that gear have a hub on the opposite side?
Can you give me the OD of the gear and hub (if it has one) and the ID of the bore?
You could also try calling RV Salvage and see if they have any of them.
Gotta go campin!
Old 04-25-2018, 04:18 PM   #6
There is no hub on the other side. He said the OD is about 1 5/8” and the inside is about 5/8”
Old 04-25-2018, 04:20 PM   #7
Head Rambler
I'll do some searching for one, but you should call RV Salvage and see if they have one in the mean time. You may get lucky and they have a few in stock.
Gotta go campin!
Old 04-25-2018, 05:03 PM   #8
Yeah, after you suggested that I printed out a list of them. Is there a specific one you suggest?
Old 04-25-2018, 05:49 PM   #9
larry2c's Avatar
One other possibility would be to find a quality machine shop and see if they could repair the gear. It would require welding - if the gear material allows that - and then re-cutting the teeth. Wouldn't be cheap but a lot cheaper than the replacement Lippert said you'd need.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-25-2018, 05:53 PM   #10
That’s something I hadn’t thought of. I know our repairman has had parts machined in the past. I’ll mention it to him. Thanks.
Old 04-25-2018, 06:23 PM   #11
rebeltown's Avatar
I can't believe that the gear is only made for the use on your slide. Most manufacturers use common hardware that is cheap and available on the open market. Search the internet for gear sets. You might get lucky. Ask Lippert where they buy theirs...
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 04-25-2018, 06:41 PM   #12
Another possibility is having a good machinist cut a brand new gear, of the appropriate dimensions, out of stock material. That would be a stronger option than welding. Unfortunately, it would likely be expensive as well. But I am sure it would be less than $2000.
BrettN is offline   Reply With Quote
Old 04-25-2018, 06:53 PM   #13
I have been searching for days. The problem is that Lippert bought out the manufacturer of that spur gear and then shut down production of that and other parts. They told us that it is now an obsolete part and that they chose to not manufacture a viable alternative part and therefore the entire hardware system would have to be replaced.
The worse part is that no matter how I try to search for m-tec I get redirected to Lippert!
It really burns me that they chose to do this as it basically forces customers in need of this $27 part to purchase an entire system from them. The hardware is around $980 and requires the removal of old stuff and the welding and install of their system so the labor is more. As many people as there are on here who jump slide gears I imagine it will become a more common problem, I mean this 5th wheel is only 7 years old smh
Old 04-25-2018, 06:54 PM   #14
Yes I’m sure. Half that cost is labor to completely strip and reinstall the slide hardware which requires more than one person and welding etc... machining a new spur would cut down considerably on labor.
Old 04-26-2018, 02:23 PM   #15
Royston's Avatar
Probably other manufacturers but this came up from a Google search of Gear sets. Welcome to rushgears.com - Nobody makes custom gears faster!!!
Like others have said I can't imagine a manufacturer having special gears made, they would have choses stock gears to keep the cost down. Good luck with your search and I hope you get it resolved soon
2011 Berkshire 390RB (Front airbag upgrade & 275/80R tires)
2016 Ford Edge SEL 3.5ltr, Blue Ox baseplate, Ready Brute Elite tow bar, Brake Buddy Advantage Select
Royston is offline   Reply With Quote
Old 04-26-2018, 02:28 PM   #16
Head Rambler
Here's a pinion gear that may work. You (or the repair guy) could take it to a machine shop and have the hub cut off and it should fit the rack and the shaft.
18 Tooth, 1.667" OD, 5/8" Bore, Spur Gear
I didn't find one without the hub, but it's pretty easy to machine the hub off.
Gotta go campin!
Old 04-26-2018, 07:37 PM   #17
Garrette's Avatar
Call Tonys Rv in Lexington.
http://tonysrv.com
The only repair RV's not sell. Call and speak to Gerald. He is very knowledgeable.
You could email you problem and pictures for a repair quote at partsmanager@tonysrv.com
I have relied on them for service, wheel well repair and slide repair and other items. I found them honest and though and they will work your insurance claim if applicable.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-26-2018, 07:40 PM   #18
Thanks Garrette, I’ll give that a try.
Old 04-26-2018, 08:15 PM   #19
FordHauler's Avatar
Visone RV in East Bernstadt, KY. is one of the largest RV salvage operators in the country, they may be of some assistance. Good luck. 606-843-9889
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
98 gallons of diesel on board! GVWR 14,000 LB.
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 04-27-2018, 07:56 AM   #20
extremebike's Avatar
Try a company called Stock Drive. They sell gear.
Small Mechanical Components: Precision Gears, Gear Assemblies, Timing Belts, Timing Belt Pulleys, Couplings, Bearings and much more - SDP/SI
Good Luck
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
slide
