Old 08-14-2016, 11:49 AM   #1
Main slide not sitting all the way
Noticed today that my mail slide, 144", is not extending all the way in the right corner (facing slide). The other side looks to be going all the way out and sitting down properly. I attached a few pictures. It there a way I can manually fix this. My electronic buttons work but after it goes 99% of the way out it makes the grinding noise. Thanks for all your help. Click image for larger version
Name:	ImageUploadedByForest River Forums1471193343.571010.jpg
ID:	117228Click image for larger version
Name:	ImageUploadedByForest River Forums1471193365.658960.jpg
Ecook is offline   Reply With Quote
Old 08-14-2016, 03:44 PM   #2
Head Rambler
That looks like an electric thru frame slide. What RV do you have?
When you retract it do both sides come all the way in?
If the opposite side isn't coming in all the way then you can adjust the right side out a little.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-14-2016, 06:57 PM   #3
I have a wildwood 31bkis. When pulled in both sides seem to come in all the way. From the outside it looks normal.
Old 08-14-2016, 07:40 PM   #4
Head Rambler
You can try to adjust that side out a little, but if it's sealed all the way around when in, adjusting one side of it could cause it to have a gap on one side when in.
You can find service manuals for the through frame slides on Lippert's website which shows how to adjust the slide. .
Gotta go campin!
Old 08-14-2016, 07:41 PM   #5
Ok thank you. I will look for them.
slide
