Old 08-28-2015, 05:50 PM   #1
Main slide out on FR3
Our 2014 FR3 30DDS has operated fine until today. Just arrived at campsite and the main slide out moves about 2" then stops and makes a sound like an impact wrench. Rear slide out works fine. Ideas?? Of course this happens when all mechanics have gone home.
WanderingFR3 is offline   Reply With Quote
Old 08-28-2015, 05:52 PM   #2
Future Roo 23IKSS Owner
elundquist's Avatar
Look to see if something is blocking the SO from sliding out OR blocking the tracks.
Erik Lundquist
elundquist is offline   Reply With Quote
Old 08-28-2015, 05:57 PM   #3
Sounds like it could be a gear problem.
welder is online now   Reply With Quote
Old 08-28-2015, 05:57 PM   #4
Jim Schings's Avatar
Exact same thing happened to mine. FR3 Bed slide out. Went about 1/2 way and then jackhammer. (both going in and out). If you had someone outside pushing or pulling they could get it past the bad sport. The dealer had to order parts and repair it under warranty.
Try having a person or two outside pulling while you operate. That will get it out for the weekend and you MIGHT need someone to help push it back when you break camp...
Jim Schings is offline   Reply With Quote
Old 08-28-2015, 06:50 PM   #5
This seems to operate on cables and the slide out is on rollers. Jim your idea makes the sense, thanks for the info, do you know what they replaced?
Old 08-28-2015, 07:43 PM   #6
Sorry, no. I do know it took a couple weeks for them to get the part(s), but I suspect they just failed to order them when they were supposed to. Whatever it was, it is a common problem, since they knew right away what to do. Which is why I was little irritated that they didn't carry the part(s) in stock...
BTW, I actually used mine 2 or 3 times while waiting for part, by just having someone help push/pull the slide out.
Old 08-29-2015, 08:38 AM   #7
I'm glad you were able to use your slide out with help of a push or pull but since mine is the main slide, I'm afraid that it might take several people to move it. Guess we'll wait to get back to a dealer next week.
Old 08-29-2015, 12:21 PM   #8
Wolverine 1945's Avatar
THAT HAPPEN TO ME,,,
I found it to be a rag that had gotten caught on the shaft under the slide out,,,
in a storage compartment,,, Guess you know there are no more rags in that compartment !!! LIVE & LEARN !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-29-2015, 02:07 PM   #9
Had same problem. Gear box was stripped, replaced under warranty by dealer. Had to push in with help from some fields while wife operated switch. Norco accu-slide with cables. Good luck!
conddave is offline   Reply With Quote
Old 08-29-2015, 04:51 PM   #10
FR3 slide
Our 2014 FR3 had the same problem with the bedroom slide. Only difference was I had it out putting clothes in for a trip and it wouldn't go in. Long story short, the gear box had to be replaced. That was a year ago.
gfritz1939 is offline   Reply With Quote
slide, slide out
