Old 07-11-2016, 04:16 PM   #1
Main Slide Out- Rockwood 2905SS
Hey Guys,
I have an issue with my slide out. When I packed up camp earlier today, my slide went back in without a problem. When I got home and hit the switch to put the slide back out to unpack nothing happened. I don't hear anything when I hit the switch. I check the fuse panel under the fridge and none of the lights are lit up indicating a bad fuse. All of the other power accessories work fine. Any ideas what could be wrong or what else I can check?
Thank you in advance.
Mike
pal216 is offline   Reply With Quote
Old 07-11-2016, 04:51 PM   #2
Cyber Phrenologist
Radio's Avatar
It's still likely (hopefully) a fuse. Fuses for slide outs and landing gear legs are usually near the batteries not in the converter panel. Look for a heavy wire that runs through a little box. It may be mounted to something, or may not be, just hanging in space on the wire. Likely to be a 30 amp auto type fuse, or might be a resettable circuit breaker.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-11-2016, 06:03 PM   #3
Thank you Radio! That was the problem. Found this guy hanging out right where you said to look. Thanks again for your help!Click image for larger version
Name:	ImageUploadedByForest River Forums1468278215.178855.jpg
Old 07-12-2016, 08:11 AM   #4
Restcure's Avatar
Great tip!
So... did resetting the circuit breaker solve your problem?
2012 Rockwood Ultra-Lite 2701SS with ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is online now   Reply With Quote
Old 07-12-2016, 08:29 AM   #5
There is a 30A fuse inside that green cover. Pulled the bad fuse out and slapped a new one in. That was it!
Old 07-12-2016, 01:52 PM   #6
Left Coast
I'd change it out to an automatic re-settable one....Box of fuses almost pays for one..
rockwood, slide, slide out
