Old 04-23-2016, 07:02 PM   #1
Optimus's Avatar
Main slide skylight is leaking
Gents, after a 1400km trip from Canada to Tallahassee fl, it would appear my skylight window on my vengeance th is leaking like a bitch. Now that it's dry I pushed up slightly on the window and I can put my finger directly outside for about 90% of the circumference. I bought some dycor today, but I'd like some advice on how to proceed. In my mind, I'd like to lift off the window, put a bead of dycor where the previous seal was, and reseat the window, then build up the edge from the window to the slide roof with dycor. Let me know what you think
Optimus is offline   Reply With Quote
Old 04-23-2016, 07:11 PM   #2
crunchman12001's Avatar
Can you post some pics, it sure would help find a solution with you.
2015 F-250 FX4
Old 04-24-2016, 07:11 AM   #3
Optimus's Avatar
Here is the slideClick image for larger version
Name:	ImageUploadedByForest River Forums1461499796.341008.jpg
This is closer to it in its normal position Click image for larger version
Name:	ImageUploadedByForest River Forums1461499833.125585.jpg
This is me lifting it up Click image for larger version
Name:	ImageUploadedByForest River Forums1461499872.794661.jpg
Old 04-24-2016, 07:13 AM   #4
Optimus's Avatar
I do not have a ladder onsite, so I can't give you topside pics... I'm hoping to hit up the rv park to see if I can borrow one. If not I'll have to bring the slide in and reach it from inside...
Old 04-24-2016, 07:41 AM   #5
Originally Posted by Optimus View Post
Here is the slideAttachment 105901
This is closer to it in its normal position Attachment 105902
This is me lifting it up Attachment 105903
If you can just "Push it Up" there is Outside issues! You could use "Eternabond" tape to seal it BUT if you wanted to go back to "Original" there is going to be a LOT of work to remove the "Eternabond"! Did the prior owner put in the "Skylight"? When was the last time you were up on top and looked at the "Seal around the Skylight"? Youroo!!
youroo is online now   Reply With Quote
Old 04-24-2016, 08:11 AM   #6
bubbles's Avatar
The RV's that have a skylight on one of the slides (atrium etc.) that I have seen are self contained units and the domes flange typically inserts into a rubber gasket which is part of the assembly. The skylight isn't just put over the top like a typical skylight opening but anything is possible I guess.
Old 04-24-2016, 10:23 AM   #7
Optimus's Avatar
Well I went for it... Removed the glass (there was only about 4" left adhered). Cleaned the glass, gasket and roof with alcohol.
Applied a bead of dycor on the gasket, and laid the window back down, which smoothed the dycor on the glass for a larger seal. Then I laid a bead down around the outside of the glass edge to the roof... I'll probably run another bead once this one dries.
Old 04-24-2016, 10:24 AM   #8
Optimus's Avatar
Name:	ImageUploadedByForest River Forums1461511478.991325.jpg
Old 04-24-2016, 10:45 AM   #9
Never seen this type of Install but,good luck! Youroo!!
Old 02-22-2017, 07:49 PM   #10
Scuebiesnak's Avatar
Optimus, did this fix your leak? Mine did this, this week end, rained like hell.
Scuebiesnak is offline   Reply With Quote
leak, light, slide
