Old 05-13-2013, 08:00 AM   #41
Originally Posted by f1100turbo View Post
you should have a crank in your camper , you stick that in the hole and line it up with nut on the back side and crank away !
This is correct,but on some units when the crank is used it (Bypasses the clutch) which will allow Damage to slide if you crank beyond the (Normal) limits. Youroo!!
youroo is online now   Reply With Quote
