Old 05-09-2015, 05:31 PM   #1
manual slide out on wildwwod xlite
I have a 32ft wildwood xlite 281BHXL. I will be going to Yellowstone this summer and have tried to identify possible sticking points. One of those is manually cranking the slide out. I simply cannot find the shaft. I have a underbelly cover so it could possibly be there but without cutting the cover open i have no idea. Plus unless i know where to cut i would simply be guessing and wasting a lot of the cover. Anybody have a similar camper that can assist me?
rominks is offline   Reply With Quote
Old 05-09-2015, 06:08 PM   #2
fonzie's Avatar
If your slide has two rail (top and bottom) as shown in this video then you have Schwintek system and no manual crank.....search forum here for more info on how too operate etc etc
https://www.google.ca/search?q=schwi...IdOsyAS3wYGQDg
Fonzie
Old 05-09-2015, 06:15 PM   #3
Ford Idaho's Avatar
What is this used for??
Old 05-09-2015, 06:23 PM   #4
Mowgli64's Avatar
Thanks fonzie, I have a schwintek slide, hope I never need to do that it does not look easy or fun.
2015 Wildwood X-Lite 271RBXL
2013 Ford F150 Crewcab Ecoboost
Mowgli64 is offline   Reply With Quote
Old 05-09-2015, 06:26 PM   #5
Could be on the opposite side around the tire opening, if so, you should have a crank handle for it.
Old 05-10-2015, 08:56 PM   #6
Thanks Fonzie, that appears to be the answer. OldCoot, I have looked every where and it can not be found. After viewing the video I believe that it the answer for me. Now I just want to take the strip off to look at it. Personally I hope I never have that happen to me.
Old 05-11-2015, 09:57 PM   #7
WSY DD693's Avatar
Manual Slide acess points
On my Surveyor 303, The left side slide manual connector is underneath the top step of the entrance doorway in the center of the step well. On the right side, there is a grey plastic ring in the area of the city water connection at the very bottom of the trailer wall. The slides move in and out fairly easy, with the long handled crank arm. Good luck!
ID:	76746   Click image for larger version
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
manual, slide, slide out
