Old 03-27-2015, 08:39 PM   #1
manual slideout location
Well thanks to the forum we were able to locate our slideout fuse location. we got no help from the dealer, tried to contact Forest River with no luck. I went online and the info was there. Just goes to show you how valuable all you people are who submit info.
Now we haven't been able to locate the location for the manual crank out for the closet in the bedroom. Any ideas?
We have a 2014 Forest River Signature Fifth Wheel. Hoping to hear from you.
Thank you.
Dubedubedo
PS: Couldn't figure out how to post a new subject, so I hooked onto you = thanks.
Dubedubedo is offline   Reply With Quote
Old 03-27-2015, 10:51 PM   #2
Dave_Monica's Avatar
The wardrobe slide outs in the bedroom are BAL Accuslide. Manual override is a flexible hex drive to be used in an electric drill driving the gearbox which you should have received with the camper. Here's the link to more info... BAL - Innovative Products for the RV Industry
Dave
Old 03-28-2015, 11:09 AM   #3
Slider Problem
Thank you Dave & Monica. I downloaded the manual for the slideout info,. we do appreciate this forum.
Old 04-17-2015, 11:13 PM   #4
Salem 38 RDLS---
Unsure how to post a question, so tagging in on this post. I have a 2004 Salem 38 RDLS. Haven't used it in a few months due to weather. Today I tried to slide out the slide outs and the bedroom slide came completely out and the living room slide only went half way. Now the neither slide will move in or out. I was thinking hydraulic problems. Maybe air in the line or too much or not enough fluid. I bled the lines and still nothing. I put a volt meter on the battery and when I drive to move the slides it doesn't pull the battery down--almost like it is using the inverter only.........any suggestions may the solenoid switch?
summerfun is offline   Reply With Quote
