Old 01-14-2009, 09:19 PM   #1
manually extending and retracting slide
Hello,
I have a 2005 rockwood and the bedroom slide does not work. The large slide works fine, all power is on, all lights-plugs-a/c-fridge are working. The bedroom slide worked great last time we retracted it. Now nothing happens when I push the switch. How do I reach the manual override under the bed? My arms aren't long enough. Is there a special LONG tool for this? I can't see any possible way to reach it from the top or bottom side. Could it be another fuse somewhere else? I'm camping this weekend and just found out the slide isn't working. Any info would be great to hopefully repair the problem but it won't slow us down from going camping. Might just make it a little cramped though.
thanks,
Pro Deck
Pro Deck is offline   Reply With Quote
Old 01-15-2009, 01:08 PM   #2
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
The only control for a slidout is the use of a hand crank wrinch that you attach to the motor assemble. This is found underneath the slide. The crank was given to you when you bought the trailer.
As far as testing why the motor is not working, someone else here will have to help. Or may be able to call a dealer service for some over the phone help.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 01-15-2009, 03:49 PM   #3
What model of Rockwood are we talking about here?
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
bedroom slide, manual slide, technical, fuse, slide out
