Old 10-07-2016, 09:36 PM   #1
MBR slide not working
We live in a 2016 Columbus 377MB in Daytona Beach. We evacuated to the west coast yesterday. No truck so we had to leave the RV there. Got everything all battened down and went to put the MBR slide in. Hit the button and nothing. Didn't really have time to fool with it. Looked in my fuse panel and saw 4 fuses labeled S/O. Figured this means slide outs as there are 4. The other 3 worked fine. I pulled one fuse and noticed a red led went on next to the fuse. I guess this means that if a fuse is no good the LED will light up. Like I said, didn't have time to deal with it so I left the slide out. Hopefully the only damage will be a damaged slide cover. When I get back, and his willing there's no major damage, how would I go about fixing this? What else should I look for? Thanks.
rblake39 is offline   Reply With Quote
Old 10-07-2016, 09:57 PM   #2
BTW...motor is not running. Completely dead
Old 10-07-2016, 10:55 PM   #3
CaptnJohn's Avatar
The red light came on because you pulled the fuse. Pull all 4 and check for a blown one. Failing to find one there you will probably find it one of the 30 amp fuses near the battery.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 10-07-2016, 10:58 PM   #4
Thanks. Headed home tomorrow. As long as the RV is still there, I'll check all fuses.
Old 10-07-2016, 11:04 PM   #5
CaptnJohn's Avatar
Hope it is still there and no additional problems are found. Glad it is done for you. Going to hit me tomorrow ~ the worst for us looks to be around 8PM.
2016 F350 diesel
Old 10-08-2016, 01:45 PM   #6
There is a different panel for the slides it is in different places so you will have to find
Sasnett1 is offline   Reply With Quote
slide
