Old 08-13-2013, 06:37 PM   #1
Smile Micro Lite 25ks slide retracted questions
We're thinking of purchasing this model from a dealer in Greencastle, PA as the cabinet space/storage is abundant and it still is a small and light weight TT. With the slide retracted, the bathroom route is blocked and the murphy bed is inoperable. Seems that means sleeping on the couch or turning the u-shaped dinette into a bed for a quick overnight stop en route. Not sure if the fridge is blocked from opening or not. If only FR would have curved the corners of that dinette, I think we could squeeze through! Still on the fence about the purchase and would love to know your experiences with this floor plan. Thanks a bunch!
Debbie Flanigan is offline   Reply With Quote
Old 08-13-2013, 07:23 PM   #2
Blackrock's Avatar
If the 25KS slide is as simple as the slide on my 25DS it's just a matter of zip it out and zip it in. The 25DS does have that extra door to the rear that makes it handy for side of the road potty stops. As for a quick overniter I have run the jacks down, put the slide out out and never unhitched.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 03-03-2014, 08:48 AM   #3
The 25KS has a rear door allowing you to access the bathroom from outside, so no issue there when the slide is in. The refer is also aft of the slide, so you can access it by passing through the lavatory if you cannot squeeze between the kitchen and the dinette.
BigBlueFan is offline   Reply With Quote
slide
