Old 07-21-2015, 08:32 PM   #1
Mini Lite slide adjust
Good evening,
This spring when I was applying silicone to the slide seals I noticed that the front seal was extremely tight while the rear seal was barely touching and actually falling into the opening somewhat. Everything was working and I had a few trips lined up so I decided not to mess with it for the time being. After a little google searching I decided to attempt adjusting today versus taking it back to RVW which is about 4hrs away. Really happy with how it turned out with the exception of my stripes on the side of trailer now have a noticeable space between them but thats only cosmetic and I feel better knowing my slide is in the right spot front to rear. Next item on the list is to adjust the lower section in at the bottom to create a better seal as it has always had a gap in which you can see daylight through but that will have to wait till another day. Hopefully the before and after pictures will post correctly.
2015 Rockwood Mini Lite 2504s
2015 Toyota Tundra Crewmax
Equal-i-zer hitch
Nights camped 2014 - 6
Nights camped 2015 - 20
AFitz is offline   Reply With Quote
