Old 09-18-2011, 05:30 PM   #1
mini lite slide roller brackets problems
I am very dissapointed about the way the rollers brackets are installed on the mini lite. They installed the brackets over the rubber flap and created a very weak point by doing it this way. There should be a cut insert to fit the roller bracket directly on the wall and not the way it is. The bracket overlap one eight of an inch because of this rubber. Considering the weight these brackets are supporting they should be flat on the wall. Is anyone of you ended up with issues because of this. I checked the screws on these brackets and some were loose. If a bracket fail while the slide is in the open position we are toasted for sure. I have included some photos to show what I mean!!!!! If we cut the rubber for the fit it will create a opening under where the rubber is sealing.
ID:	8102   Click image for larger version
ID:	8103   Click image for larger version
ID:	8104   Click image for larger version
capucine is offline   Reply With Quote
