Old 05-19-2013, 01:32 PM   #1
MattMcK's Avatar
Move trailer on site w/slideout open?
My trailer is already set up on my seasonal site. Now to make it perfectly level I need to remove a board under one side. Can I leave the slide-out fully extended while I pull the trailer forward 5' to take out the board and then back the trailer back into its spot? Or should I retract the slide-out just for this short trip of a few feet?
MattMcK is offline   Reply With Quote
Old 05-19-2013, 01:38 PM   #2
clancythecamper's Avatar
You won't regret sliding it in, releveling, then sliding it back out.
clancythecamper is offline   Reply With Quote
Old 05-19-2013, 01:45 PM   #3
X2. It will be very difficult to level the jacks with a slide out hanging excess weight off the one side. Slide it in, re-level, then slide it out again. Should not be too much trouble.
Old 05-19-2013, 01:52 PM   #4
Poppy94's Avatar
shorcuts cost more than they're worth. suck it in, move it, slide it out. i mean, really? you're pushing a button. not hard at all. go ahead, do it. push the buttons.
Poppy94 is offline   Reply With Quote
Old 05-19-2013, 01:54 PM   #5
Push that button ......I would never move a trailer with the slide out not in position even for a few feet. The frames on these things flex ...
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
