Old 07-09-2016, 02:05 PM   #1
Mr. (Using stabilizers under slideout)
I have a 35ft Rockwood trailer with three slideouts. The trailer is in a permanent spot in a campground. It is new this year in April, will probably not be towed unless I decide to go south for the winter. I am wondering if the warranty will be affected if I put stabilizers under the slideouts. I know they do not have to be there and I know the slideouts are not to be "jacked" up. I put the stabilizers under them simply to keep them from "bouncing" in any way when walking in them. They are only snugged up so they are tight.
I was hoping to get this to someone from Forest River but not sure how to do that so decided to try this.
Thank you in advance.
Galland Burnham is offline   Reply With Quote
Old 07-09-2016, 02:27 PM   #2
B and B's Avatar
The slides are supported by the trailer walls. Putting anything under the slides will either break the gear that moves the slides in and out or cause issues with the drop down floor level joint causing it to jam. Better to put JT strong-arms on the stab jacks to stabilize and also use X-Chocks on the wheels. Then if not enough a inexpensive scissors jack between the tires on the subframe to tighten things up.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 07-09-2016, 02:59 PM   #3
Ford Idaho's Avatar
Crib it up and remove the tires.
The suspension and tires is where the bounce comes from.
Old 07-09-2016, 03:06 PM   #4
wmtire's Avatar
Just a quick refresher for those who may not be aware. Forest River Forums is not owned nor controlled by Forest River, Inc. This disclaimer is at the bottom of every page here, when using the web version of the site. Although we share the name, these are two separate entities.
There are many reps and employees here on the forums who are employed by Forest River, Inc. who do their best to try and help their customers and our members...... but you cannot count on them seeing a post here.
Also, I am going to edit this thread title, so others may see it in the forums list and may can offer assistance.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-09-2016, 03:38 PM   #5
This guy tried what you are proposing and Still had BAD results! He had (14) jacks under it! Crib the Frame since you are Perm! Youroo!!
ID:	113567   Click image for larger version
ID:	113568   Click image for larger version
Old 07-10-2016, 02:17 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I use 4 jackstands that I got from Wally World for about $35. I put them between the stabe's and the wheels. Just snug them up to be solid. NOT MEANT TO BE LEVELERS!! I've heard that it's not healthy to put anything under the slides. To each his own, though.
Grampa Jim is offline   Reply With Quote
Old 07-10-2016, 04:01 PM   #7
Fulltime family RVer
Don't do it. My owners manually specifically said not to (Sabre fifth wheel).
You can use the Contact Us from on www.forestriverinc.com to contact your warranty manager, I believe.
Old 07-10-2016, 04:35 PM   #8
X2
Wiscampsin is online now   Reply With Quote
