Old 05-12-2016, 11:01 PM   #11
Slide out
Originally Posted by 830hvacman View Post
Check out my repair back in Feb 2015 on my Crusader.
Thread title: Slide out /Underside wearing
and go near bottom of page 48. with pics.. I used some UHMW that was machined with regular wood working tools.
Now - I know the repair was doing great for about 3 months, then I traded it in for a diff brand with hard plastic bottom and rollers.
I wish I knew who purchased it just to follow up on my repair.
Do you have any pictures of this?
wildwoodtraveler is offline   Reply With Quote
Old 05-12-2016, 11:03 PM   #12
Slide out
Did you take any pictures of your repair? What is UHMW?
Old 05-13-2016, 01:41 AM   #13
2007 WildCat 32QBBS
05CrewDually's Avatar
UHMW - Ultra High Molecular Weight Polyethylene
In other words, plastic sheet.
05CrewDually is offline   Reply With Quote
Old 05-13-2016, 07:26 AM   #14
dieselguy's Avatar
My rig is at storage right now, I'll get a photo in a few days. It's just lengths of hard black plastic angle about 4" wide with a 1 " lip that goes under your end trim piece. Since my dealer is worthless, I just called the factory warranty division and had it sent to my home. There was a thread several months back on here that had photos ... I don't remember the FR line of RV.
dieselguy is offline   Reply With Quote
Old 05-13-2016, 12:44 PM   #15
pix
I used a pneumatic stapler the second time around and found out at the edge you can only use a 6mm or 1/4 inch staple. The reason they were pulling out is there is a metal frame under the wood and the longer staples were not seating all the way. Then when the room came in or out they were rolling out .
ID:	107748   Click image for larger version
ID:	107749   Click image for larger version
k4lp is offline   Reply With Quote
Old 05-13-2016, 05:35 PM   #16
Texas
Yes, I did post the pictures back in Feb. 2015, just do a search on the title, and then go to page 48 - It is a large thread...
Hope that helps!
Ken
830hvacman is offline   Reply With Quote
Old 05-14-2016, 12:03 AM   #17
Thanks! I will try to locate the thread. Wish me luck!
Old 05-15-2016, 06:08 PM   #18
2007 WildCat 32QBBS
Just got back from Home Depot with my 6 dollar fix. 1 1/8 X 1 1/8 X 1/8 corner gaurd.
http://www.homedepot.com/p/Trimaco-1...184G/100118843
Old 05-15-2016, 07:03 PM   #19
I sure wish that would work on mine but only have about 1/2 inch on vertical side. Hope it works great for your fix.
Old 05-15-2016, 11:22 PM   #20
2007 WildCat 32QBBS
They have it in 5/8" too. But in your case you can either tuck the long edge under the vertical existing trim or trim the corner guard with a razor to fit.
slide, slide out
