Old 05-14-2011, 09:35 PM   #1
Need slide out help
I just purchased a 2004 Sunseeker Class C with a living room slide. The slide does not operate, no noise, nothing. The fuse is good, but I cant find the breaker. Can someone tell me where it is, or what my problem may be.
hannigan13 is offline   Reply With Quote
Old 05-15-2011, 07:03 AM   #2
look under the trailer tongue 30 amp fuse block should fix
1st SGT is offline   Reply With Quote
Old 05-15-2011, 07:29 AM   #3
If you have a fuse there will be a little light and then it will tell you that the fuse is out and you might have to go under the camper and access the pump that puts the slide out and there might be a fuse there
Matthews1 is offline   Reply With Quote
Old 05-15-2011, 07:36 PM   #4
Class C motor home not a trailer, thanks for the help though.
