Old 07-07-2014, 01:19 PM   #1
no power to slide on 23SS
I have a Shamrock 23ss and the power slide will not work. However we have power to everything else including the awning. We were able to close manually. AC, lights, outlets, awning all good. No power at slide or switch.
idler186 is offline   Reply With Quote
Old 07-07-2014, 01:30 PM   #2
KMP44's Avatar
Check underneath - there is a 30 amp fuse in line on the wire to the slide motor.
You may want to replace it with a resettable breaker or get a couple spare fuses, just in case...
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 07-07-2014, 01:58 PM   #3
Thanks we will try that!
Old 07-07-2014, 02:51 PM   #4
That was it, thanks!
23ss, power, slide
