Old 09-07-2014, 03:16 PM   #1
Lippend
no power to slide out motor
2008 Cedar Creek with no power to slide out motor. Following supply wire to back wall of front storage area, wire is connected to "power strip" with 2 copper strips, over and under. Upper strip has power, lower does not and that is where wire is connected.
If I jump from batteries to positive lead on trombetta and ground, slides work fine from inside switch.
30 amp auto fuse in breaker panel is fine on/off switch for slide is fine.
Any suggestions?
Thanks.
lippend is offline   Reply With Quote
power, slide, slide out
