Old 09-05-2018, 03:45 PM   #1
No power to slides
On shore power I just moved out a wall slide half way to load the fridge, a couple minutes latter I now power to retract it, I checked the other 2 slides and now power as well, every thing else that is AC is working fine including the awning is there a breaker that would control all three slides somewhere. Not a fuse or breaker in the main panel for slides
sdp0962 is offline   Reply With Quote
Old 09-05-2018, 03:47 PM   #2
ejohnson1144's Avatar
What do you have ? Slides work on 12v
ejohnson1144 is offline   Reply With Quote
Old 09-05-2018, 04:32 PM   #3
bikendan's Avatar
Without posting year/make/model of RV or have it listed in your profile, it's kinda hard to help.
Equalizer WDH
Old 09-05-2018, 04:45 PM   #4
Sorry haven’t used forms before it’s a 2017 forest river flagstaff classic superlight fifth wheel with electric slide
Old 09-05-2018, 04:45 PM   #5
NMWildcat's Avatar
Problems with slides are usually low battery and/or 12v fuse related. Usually the fuses are in the fuse block/panel and/or close to the battery.
Scott and Liz - Southern NM
Old 09-06-2018, 01:08 PM   #6
TGR
TGR's Avatar
My Wildcat 5th wheel trailer has an inline fuse leaving a terminal strip loosely covered by a rubber shield and mounted near the battery. The slides work even when the battery disconnect is in the disconnect position.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 09-06-2018, 06:14 PM   #7
Head Rambler
You should have a 12volt breaker in the slide circuit. It should be near the battery, and it may be hidden in the wire loom.
Gotta go campin!
Old 09-06-2018, 07:02 PM   #8
FORKLIFMAN's Avatar
did you check batteries ? are they dead?
FORKLIFMAN is offline   Reply With Quote
power, slide
