Old 08-24-2016, 11:52 AM   #11
BandJCarm's Avatar
Thanks!!! But then I'm at a loss as to what is causing the issue.
Emailed CC and they said "Make sure it's level"............. and it is, it's in my level concrete driveway now, and still does it.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 08-24-2016, 12:29 PM   #12
DDC
DDC's Avatar
Go to the LCI web site and check their FAQ and if you can't find anything there they do have a call centre, I was talking to a couple of them last week, its not overseas so you will be able to understand them and they really know their stuff. Good luck.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-24-2016, 12:38 PM   #13
DDC
DDC's Avatar
Found the card they gave me, phone is 574 537 8900
e-mail is customer service@lci1.com
Old 08-24-2016, 12:45 PM   #14
BandJCarm's Avatar
Thanks!!
I've emailed them.................. we'll see what happens.
I found some old threads on the subject......but nothing definitive that hasn't already been mentioned and checked here.
Thanks again.
FROG AR-0019-242
Old 08-24-2016, 12:46 PM   #15
AquaMan's Avatar
Does the pump change tones after the one slide comes in, or does it stay the same?
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-24-2016, 01:02 PM   #16
BandJCarm's Avatar
Well......it starts staying the same........but after a second or two when the slide is just NOT going to move, it starts to strain somewhat. Not awful, although the noise of the slides going in was bad.........before I lubed the tracks. Lubing helped that noise.....
FROG AR-0019-242
Old 08-24-2016, 02:15 PM   #17
downtime's Avatar
With the slides in(legs up) the level should be 1/2 in from top. I drained siphoned mine out and refiled with dextron 6 synthetic as cold here can be an issue.
Check battery cable that goes up to a 30amp reset able breakers (close to battery) as I had a few wires loose as well as a main cable wire that the end was loose from the fitting. After fixing these my slides went in with out stopping and resetting breakers.
Life is short and none of us are all that Tall !
downtime is offline   Reply With Quote
Old 08-24-2016, 02:21 PM   #18
BandJCarm's Avatar
Another good suggestion, thanks. I have Four 6v batteries and there is zero room........adding water was a CHORE! But I will go look for that. You have made me think/wonder if I truly tightened every battery connection after loosening them to add water.......I'm SURE I did, I remember it distinctly......but my memorator is broken so maybe that is the issue.
DW says I have to also do work on our non-mobile house.....which has been neglected since this trailer arrived. But I will check that as soon as I can.
Thanks again.
FROG AR-0019-242
Old 08-24-2016, 02:33 PM   #19
BandJCarm's Avatar
No loose wires.
Dang.
FROG AR-0019-242
Old 08-24-2016, 10:45 PM   #20
Slide out
I have read with interest comments about malfunctioning slide outs. I got frustrated with having to repeatedly replace the inline fuse under the trailer, or use the manual crank. So I dismantled the slide out motor and simply push the slide out in and out. It's no big deal, other than to remember to place the lock bar when fully retracted and travelling. This saves me a lot of headaches.
Hector517 is offline   Reply With Quote
