Old 06-22-2013, 07:24 PM   #1
cmhbob's Avatar
One More Stuck Slide
Sandpiper 35Loft. We were fulltiming, but landed about a year ago. Rig's been parked since then. Slides were out for a while, then in for a while, then back out.
We're using it for shelter for a fireworks stand. When I moved it from the house to the stand site, I ran the slides in just fine (on shore power). When I went to set it up, with a brand new house battery, the 3 slides ran out seemingly fine, but then I noticed the main LR slide stopped about 6 inches or so from fully extended. Can't recall if I was on house battery or generator at the time.
At any rate, when i hit either the main switch on the inside control panel or the aux switch at the hydraulic motor, all I get is a relay or solenoid click. The motor won't even burp. This happens either on house or shore power. Suggestions? I've checked the 3 inline fuses in the forward cargo compartment that I can find (2x30s and 1x10), as well as all of the fuses on the electrical center (bunch of 15s, and 2x30s that are under the cover). Are there any others I'm missing? Any ideas for testing? I have a multimeter available.
I've got the crank, but I'm not seeing where to attach it. The only nut that looked like it would work was too large for what was supposed to be the slide crank, and I wouldn't have had room to rotate that crank anyway. Is that crank only for the 2 smaller slides? Our LR slide is 10-12 feet or so.
When I look at the motor and pump, I see the little paper cover that I can remove to access the drill system. Is that the only place to manually run the system? The silver section with the hydraulic lines coming out is just the manifold, right?
And of course, someone called today to see the rig tomorrow.
Name:	Slide pump 640.jpg
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 06-23-2013, 04:36 PM   #2
cmhbob's Avatar
Update: I was able to use my cordless drill to run the slide the rest of the way out. But as far as I can tell, the motor is still out, which is disconcerting. Anyone have any suggestions for troubleshooting?
Showed the rig today, too. They seemed very interested.
More About Me
Old 06-25-2013, 12:37 PM   #3
Dallas Texas
TexasBBQ's Avatar
Did you verify power at the motor lug? Is it properly grounded?
When you press the slidout swtich can you fell the motor grab or do you hear it hum?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 06-25-2013, 12:46 PM   #4
Dave_Monica's Avatar
FWIW, here's a link to the owner's manual for LCI hydraulic slide system from their web site...perhaps it will help. http://lci1.com/images/Flyers/Owners...de-out-web.pdf
Dave
Old 06-28-2013, 12:20 PM   #5
Dallas Texas
TexasBBQ's Avatar
Dave - Thanks for posting that manual. I was going to but left my thumb drive at home.
2004 Cardinal 33CKT
