Old 09-30-2012, 05:34 PM   #1
2005 Rockwood 8313S
Question One of 2 slideouts not working
Just bought a 2005 Rockwood 8313S with 2 slideouts. One slide out is now not working. WHY? Fuses appear to be good, underside is covered so I cannot see below. i also cannot see how to handcrank. Thx for any info on this model.
guesthouse is offline   Reply With Quote
Old 10-01-2012, 01:30 PM   #2
PINTO
Kpinto's Avatar
Go to the battery, trace hot wire from battery to small breaker(s) on wall, check connections to make sure all is tight and in working order. had one were the rubber from the cover was caught under the wire connector not allowing it to make a connection. If everything looks good, feel around the block for a small plastic piece sticking out of block. If it is out, push it back in, this is a circuit breaker and by pushing that piece back in you re-set it. Hope this helps
PINTO
2011 Flagstaff 8528 TBWS
2008 Duramax Diesel
Chevy 3500 LTZ Dually
Kpinto is offline   Reply With Quote
Old 10-01-2012, 08:31 PM   #3
2005 Rockwood 8313S
thanks Pinto, I tried to follow this. From the battery, i have wires going along the hitch to 3 small black boxes with 2 posts. They are before the trailer body starts. There was also a 30 amp fuse in a plastic container. Is this where you are talking about? There was one tiny little black dot that kinda broke off when I pushed it.You mentioned the wall, these were on the hitch. Is that the same?
Old 10-02-2012, 07:39 AM   #4
PINTO
Kpinto's Avatar
Sounds like you are in the correct area. If you have a meter see if you have power (12V) on both of the post. The black dot that broke off could mean it did not reset? These are little circuit breakers. Keep me posted.
PINTO
2008 Duramax Diesel
