Originally Posted by Shell
I have a 2002 37ft Sandpiper that has 3 hydraulic slide outs.
PROBLEM - The main living room slide out will not open. The bedroom and the smaller living room slide will open. All of the slide out started moving out slowly and the main slide would not open without someone helping it by way of a good back pushing. I took the pump off and had a hydraulic shop look at it, they said the pump was going bad and I should call the manufacture to find out about a replacement pump. So I put a Lippert pump (643150) in it. Now the the bedroom and small living room will move in and out without any problems. I took the main slide out hydraulic ram off and had new sealsite put in it but that hasn't helped. So what should I do next? I live in a small town that has no RV shop within 2 to 3 hour drive.
I don't know much about those, except if you weren't plugged in and operating off of the battery the battery needs a really good charge to make the slide outs work. If you are plugged in make sure the battery is being charged and the converter is working. On my Georgetown the two smaller slides work easily but the larger front slide is slower. The weight of my main slide could be is much as both of the two smaller slides, so it moves slower. If there were any other restrictions it might not open.
When you had the hydraulic ram off did you try to move the slide out by hand to see if it was hanging up? Also make sure the hydraulic fluid is full.
One last thing, is the RV level while putting out the slides. If the main slide was trying to move up hill it might not move. Sorry I can't be of any more help then this. When some of the others on the forum see your problem they maybe able to help you.
Good luck.
