Old 03-22-2017, 02:15 PM   #1
Partial slide out extension
I've got the '17 2618VS. Is it acceptable from a structural standpoint to partially extend the sofa slide in order to get from the aft bedroom to the living/kitchen area when on an overnight road side rest stop?
av8ur is offline   Reply With Quote
Old 03-22-2017, 02:17 PM   #2
Insert witty title here
From a structural standpoint, you should be fine. However, the slides are only sealed when fully extended or fully closed. Leaving them open partially could subject you to leaks.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 03-22-2017, 02:21 PM   #3
Thanks Tim. A point I did not consider.
Old 03-22-2017, 02:36 PM   #4
Left Coast
And the inner edge of slide floor might be alittle weak...
Old 03-22-2017, 02:40 PM   #5
Good info Bob. I do recall noticing the edge of the slide floor being a bit off the TT floor when in transit.
Old 03-23-2017, 01:27 PM   #6
CaptnJohn's Avatar
Dry weather and acceptable temps you should be fine if you do not walk on it.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 03-23-2017, 02:19 PM   #7
Always Learning
If they're Schwintek slides (the kind with 2 rails on either side of the slide box), don't do it. They're designed to run fully out and fully in and synchronize the motors at full extension/retraction.
slide, slide out
