Old 10-28-2015, 07:11 AM   #1
Partially extended?
Is it ok to leave a slide out partially extended?
The space where I will park the trailer for the winter is not big enough to fully extend the slide.
With it partially extended I have better access inside, but am I asking for trouble with leaking?
We live in Colorado... There will be snow on top of the slide off/on all season.
2015 Wildwood 28DBhD
Jhkahuna is offline   Reply With Quote
Old 10-28-2015, 07:19 AM   #2
LittlePM's Avatar
I don't think it's a good idea, you will have leaks, and critters can get in
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 10-28-2015, 07:20 AM   #3
mark0224's Avatar
If you only put it out part way it won't seal right and you could get water in. Also with melting snow you may get ice in between the slide and the wall that could cause damage. I would put it in for the winter, once it's closed for the winter I just poke my head in the doors to ck I don't go in and track snow in.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-28-2015, 07:54 AM   #4
mcnabbwr's Avatar
Slides should be fully extended or retracted, anywhere in between will lead to leaks. I always have mine in during storage, less chance of any kind of damage.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-28-2015, 08:02 AM   #5
X 2 Youroo!!
