Problem with hydraulic slide jam nuts
I had my RV in the repair shop for the reason of the slide "walking out" ... along with the hydraulic line leaking. I have a 2010 Georgetown 378 with only 7k miles on it and I am the original owner. The RV has been extremely well maintained and is in excellent condition. To my dismay, the repair shop could not make the repair as it is the jam nuts on the slide out ram causing the issue. I took pictures of the issue and plan on contacting Forest River as this is a manufacturing defect. I don't know if they're aware of this problem. All 3 slides are affected and the cost of this repair will be astronomical when it is clearly a manufacturing defect. The reputable repair shop mentioned this has to be repaired as eventually the slides will continue to move out on their own and he rod will bend which could cause the slide to drop. Please let me know if anyone else has the same issue.
