Old 02-05-2018, 07:57 PM   #1
Propane lines and plumbing in the slideouts
It seems that fewer and fewer MH's are free of propane lines or plumbing lines in slideouts. This seems like asking for trouble. Those of you that have such plumbing in the slides what has been your experience, especially after a number of years of use?
AbdRahim is offline   Reply With Quote
Old 02-05-2018, 08:10 PM   #2
Can't speak for water line plumbing, but have had propane in slide outs since 2010 without issue.
Rich5117 is offline   Reply With Quote
Old 02-05-2018, 09:38 PM   #3
Fulltime family RVer
Almost 6 year old camper. I have a sink in my outdoor kitchen which is on a slide out. It has a drain to a tank that we rarely use (we keep a sprayer hose almost always hooked up).
I had a water leak with both the hot and cold lines during a cold snap in Texas. It was inside the camper in the very rear corner where no heat goes, so I canít blame the slide.
For the first 3 years, we used the camper for 200 nights. For the last almost 3 years, weíve been fulltiming.
Old 02-05-2018, 10:52 PM   #4
bubbles's Avatar
Typically the slide portion of the LP line will be black pipe and the feed to the black pipe would be hose that extends and retracts with the slide. Have not heard of and do not have any issues with the set up for many years.
Old 02-06-2018, 02:59 PM   #5
Stormrider151's Avatar
I have a propane line in my kitchen slide. It folds with the power lines when the slide is retracted. Not the best design. I keep a close eye on that. Eventually I’ll have to replace it.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 02-06-2018, 03:02 PM   #6
jkoenig24
That's one reason I bought my 2015 Dynamax DX3-37RB. After three+ years of looking (to graduate from a 2010 Casita Spirit Deluxe Travel Trailer), the 37RB had the BEST floorplan of anything else I'd seen (and I'd seen a LOT). The two slideouts each had a 110VAC outlet, some LED lights and furniture. NO propane, water supply, waste lines or major appliances in either slideout. With both slides IN, my coach is ~ 98% usable (two bedroom drawers are blocked; I keep my clean underwear and socks in the top drawer). Dynamax has since changed the floorplan and now, some of the benefits I've mentioned no longer apply. I've read reports from other RVers where their rig has RUBBER propane lines. These owners have experienced damage to those propane lines from critters chewing holes! That must lead to some exciting experiences.
jkoenig24 is offline   Reply With Quote
Old 02-06-2018, 06:29 PM   #7
Dahagen
I had a 1995 Coachman class C with the stove on a slide. One day my stove and top burners quit working. Found the rubber part of the propane lines in the slide kinked. Unkinked and added a bracket...problem solved.
dahagen is offline   Reply With Quote
Old 02-06-2018, 07:05 PM   #8
bikendan's Avatar
Our previous trailer had a kitchen slideout. Double sink, faucet, microwave and stove/oven.
NEVER had any issues during the 10+ year's we owned it.
Wouldn't hesitate to get another one.
Equalizer WDH
Old 02-06-2018, 10:29 PM   #9
Great responses. Thank you. I will definitely look out for rubber hoses. Keep the responses coming.
Old 02-06-2018, 10:46 PM   #10
My kitchen is in a slideout. First trip of 2nd season I had a leak in the drain line. Easy fix. I call it a manufacturing defect, not a design problem. Problem appears to have been that the flexible hose was not fastened in line with the hard plastic piping.
As found; you can see the flex isn't in line with the PVC:
Name:	Drain slip joint connection - cracked end.jpg
Cracked single-piece slip joint:
Name:	Drain slip joint nut - old - side view.jpg
New two-piece slip joint from Menards:
Name:	Drain slip joint nut - new.jpg
I moved the clamp over to the right to keep the flex in line with the PVC.
As I've responded to others with a similar question: It wouldn't stop me from buying another TT with a kitchen slide.
2011 Traverse LT, 3.6L, FWD
plumbing, propane, slide
