Old 08-17-2013, 10:50 AM   #1
BAYDOG's Avatar
Pump runs, nothing moves
I have a 99 Cardinal with two slides, was a gift from the in laws. Pulled it up from Fl to NY, and no problems in and out many times. Not I have them out at home, and they will not retract back in? Fluid was extremely low, filled that up with Transmission fluid. Pump seems to run. Is there a way to maybe bleed the air out? or prime the pump?
BAYDOG is offline   Reply With Quote
Old 08-17-2013, 11:03 AM   #2
Dave_Monica's Avatar
Here's a link to Lipperts hydraulic slideout operating manual...you may find the answer there... http://lci1.com/images/Flyers/Owners...de-out-web.pdf
Dave
Old 08-17-2013, 01:39 PM   #3
BAYDOG's Avatar
Thanks will take a look.
Luke 6:38
Give, and it will be given to you. A good measure, pressed down, shaken together and running over, will be poured into your lap. For with the measure you use, it will be measured to you.
pump
