Old 04-26-2014, 06:19 PM   #1
Smile Question about extending/retracting slideouts on 2011 Georgetown 337 DS
We recently purchased a 2011 Georgetown 337 DS motorhome. The tech people at the dealership told us to do the following when extending/retracting the slideouts. We have two (i.e., full side slideout on driver's side and bedroom slide out(.
  • First level coach.
  • Make sure break is set.
  • Do not be running the engine.
  • Click the "slide control" button on the control panel (in/out) as appropriate.
  • When the slideout is either in/out as needed, quite holding the "slide control" button on the control panel.
  • Check the slide to see that it appears to be out properly, both inside and outside the coach.
The above steps are similar to steps we followed with our Winnebago Sightseer. The difference is that we were told to have the coach engine running when extending/retracting slideouts.
Are steps listed above that we're following for our Georgetown 337 DS correct?
Thanks in advance for your help.
Rick in Palm Springs
ricklillie is offline   Reply With Quote
Old 04-26-2014, 06:25 PM   #2
bubbles's Avatar
Yes, correct. Actually, I think there is an interlock between the slides and coach engine that will prevent slide deploying with engine running (safety kill circuit).
Old 04-26-2014, 06:38 PM   #3
Thank you for guidance on extending/retracting Georgetown slides
Thank you for confirming that we are extending/retracting slides on our Georgetown coach properly. I appreciate your quick response.
georgetown, slide, slide out
