Old 08-29-2016, 10:44 AM   #1
Rain water leaks in both front slides 2014 Georgetown 378
Took our maiden voyage in our "new" 2014 378 and discovered both of the front slides are taking in rain water. The street side is leaking over the sofa down from the valance and blinds also one of the overhead cabinets was damp on the inside. The curb side slide's carpet was wet where the carpet on the slide overlaps the carpet on the floor next to the stairs. Also found water in the compartment under the fireplace. And ideas on where this these leaks are coming from? We were set-up & level.
jsmwrm is offline   Reply With Quote
Old 08-29-2016, 10:53 AM   #2
RudysWorld's Avatar
Our 2011 350 main slide was leaking, tech said there was a void in caulk in the center of the slide. One bolt was missing in bracket holding slide topper. They caulked around the topper brackets and removed screws, caulked in screw holes, replaced missing screw and caulked void. Ours would only leak in some situations not all the time and not with slide in. Hasn't leaked since but just had repairs done. Hope this helps.
Rudy - 10 year old long haired dachshund
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 08-29-2016, 04:40 PM   #3
Thanks for your reply Rudy, will check out the mounting brackets.
2014, georgetown, leak, slide, water, water leak, slide out
