Old 01-19-2019, 11:10 AM   #1
Ratchet noise when closing
I am new to slide outs. The dealer said that a Ratchet noise when the slides reach full open or close is normal. My 2016 Roo 23ikss has 2 slides Dinette/sofa slide ratchets but the stove/kitchen slide does not. Both seem to close and open fully and operate smoothly. Is there something I need to take care of? I have a Schwintek slides.
jrctoby is offline   Reply With Quote
Old 01-19-2019, 11:26 AM   #2
heavynlori's Avatar
Our Schwintek slide does not make a ratchet sound but the other two non-Schwintek slides do ratchet when open/close fully
heavynlori is offline   Reply With Quote
Old 01-19-2019, 11:34 AM   #3
cavie's Avatar
They mix slide manufacturers on 1 RV?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-19-2019, 11:54 AM   #4
heavynlori's Avatar
Yes common practice - our neighbor has a Jayco and ours is a Prime Time
Both units have both kinds of slides
Old 01-19-2019, 01:14 PM   #5
Be aware there may be times they just stop, in or out, without any ratchet. That is also normal. So when the slide stops going in or out you can take your finger off the switch. After a few times you will know when you are open and closed.
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 01-19-2019, 03:15 PM   #6
Filterman's Avatar
X2 Itís only if you push the slide slightly beyond its open or close limits that you heard the ratchet. I tend to bring it in or out to the point you can visibly see itís travel is complete and then just give it a touch to snug it up.
Filterman is offline   Reply With Quote
Old 01-19-2019, 03:46 PM   #7
bikendan's Avatar
Yes they do.
Equalizer WDH
Old 01-19-2019, 03:54 PM   #8
koller1509's Avatar
They use different models because of the differences in the sizes of slides.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 01-19-2019, 04:08 PM   #9
Citrus County, Fl.
GL1800Rider's Avatar
If the slide you have that doesn't make the ratchet sound is a Schwintek, make sure you hold the button down at least 5 seconds after extending and retracting to prevent the motors from getting out of sync.
Here is what the slide tracks look like on a Schwintek
Name:	Schwintek slide track.jpg
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 01-19-2019, 04:32 PM   #10
tc cruiser's Avatar
Good to know as my E pro has a schwintek slide and I only put it out til it stops then take my finger off the switch. I was afraid to break something. It was never explained to me to hold it for 5 seconds after full extension or retraction.
TC
2018 Flagstaff E-Pro 19 fbs
tc cruiser is offline   Reply With Quote
noise
