Old 02-28-2019, 10:43 PM   #1
Rear slide not showing up on control panel
We recently purchased a Diesel Forest River Forester MBS. We looked on the control panel today to put out side and rear slides. The readout showed the side slide only, which we were able to slide out. It did not show the rear slide at all. Not sure why it isn’t showing up. Any suggestions? We have the RV plugged in and the batteries are fully charged. If you have a suggestion or answer could you email to: clmeyer04@yahoo.com
Meyecl1 is offline   Reply With Quote
Old 02-28-2019, 10:59 PM   #2
Usually Confused Member
emm-dee's Avatar
If you have the LCI OneControl there may be a comm interruption. Use a tiny probe to insert into the “reset” hole. Might work..can’t hurt. I had that problem once when the awning didn’t show up. Reset fixed it.
Do you have the phone/tablet app? It is actually more reliable.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 02-28-2019, 11:13 PM   #3
No what is that phone tablet app?
Old 02-28-2019, 11:34 PM   #4
emm-dee's Avatar
So, do you have the OneControl lcd readout panel which controls lights, slides, awning etc? If so, search the App Store for LCI OneControl. For Android itís at https://play.google.com/store/apps/d...d=com.lci1.one.
Old 02-28-2019, 11:46 PM   #5
Oh yes I remember now that someone mentioned there was an app...thank you for the reminder.
Old 03-03-2019, 02:35 PM   #6
Our slide disappeared from the control panel once (the day we bought it). I rebooted it by turning the power disconnect switch off and then back on. When it finished booting up, the slide was there again. Haven't seen the problem since.
CyrusL is offline   Reply With Quote
Old 03-03-2019, 07:37 PM   #7
When you say power disconnect switch are you talking about on the control panel or the main power switch by the door when you enter the R V? We tried the reset button on the control panel. We tried the other reset by poking a paper clip end into the hole to the reset button on the control panel. We tried turning the power switch on and off by the door. The batteries are fully charged. The parking break is engaged...still no display for rear slide : (
Old 03-03-2019, 08:13 PM   #8
I'm talking about the power cut-off by the door. The one that kills the power to the entire coach.
show, slide
