Old 03-22-2015, 12:37 PM   #1
dhuard's Avatar
Rear slider will not go out
I have a 2012 351 George Town and the rear slider will not slide out. The front one works find but not the back.
I retracted it 2 hours ago and now nothing when I try and extend it. Any suggestions? Thank you.
Darin
2012 Georgetown
dhuard is offline   Reply With Quote
Old 03-22-2015, 12:39 PM   #2
Start by checking fuses.
Old 03-22-2015, 02:38 PM   #3
dhuard's Avatar
Anyone out there have a 35 foot Georgetown and might know where to find a fuse for the rear slide out. I have not had this RV for too long...
Darin
2012 Georgetown
Old 03-22-2015, 02:47 PM   #4
Try behind the battery control cover
dolsen is offline   Reply With Quote
Old 03-22-2015, 03:14 PM   #5
dhuard's Avatar
Fuse box found thank you!!looks like a 5amp breaker is blown. Thanks everyone for helping !!
Does anyone know if the Georgetown has a manual retract for the slide outs if they get stuck out?? I'm going to bring more fuses but trying to plan ahead !
Thank you.
Darin
2012 Georgetown
Old 03-23-2015, 03:29 PM   #6
Left Coast
5 amp doesn't sound high enough for a slide.
Old 03-23-2015, 03:40 PM   #7
TURBS's Avatar
Should be 15 amp
Old 03-23-2015, 04:17 PM   #8
Left Coast
Thank you.
Darin
2012 Georgetown
Maybe 2 problems. Mine are 15 amp.
Old 03-23-2015, 04:33 PM   #9
I would replace it with an auto reset 15A.
Old 03-23-2015, 04:42 PM   #10
dhuard's Avatar
I tried calling the a dealer and the manufacturer. Forest River hasn't called me back and the dealer said to call FR to find out where the fuse for the slider. I don't think I found the correct fuse box. I have a 2012 Georgetown but in the 2015 manual they have listed in line it says...
If you have no power, first check the slide room fuse, in the main fuse panel. The fuse panel is located near the floor either in the hallway or bedroom. The correct fuse is clearly marked SLIDE ROOM, and is a 15 amp fuse.
I don't see a fuse panel near the floor in the hallway or bedroom. Anyone else have a similar model that might be able to direct me to it the fuse box? Thank you
slide
